2005 SX230 H/O - Crank/No Spark Condition on Both MR-1 Engines
SX230HO
I bought a 2005 SX230 H/O last week with excellent compression testing results. The guy I bought it from sent me videos of the boat running and revving with water hooked up the day before I arrived to compression test it. Since the compression testing passed, I bought the boat and didn't bother running it again with old spark plugs and oil. My mistake, I know.
Fast forward to today after replacing plugs, new oil and filters, new air filters, fuel additives, etc. and I can't get either engine to turn over. Batteries are fully charged and the starters sound healthy. It just cranks and cranks with no attempt at starting.
I've checked for spark by removing a single coil from each engine, attaching a new spark plug, grounding the side of the plug, then cranking. No spark from either engine. On the red wire of the ignition coil connector I get 12V while cranking, but not with key in the on position. I don't suspect the relays are both bad.
I bypassed the lanyard kill switch by shorting both sets of black and white wires and verified both the neutral switch and plug clean out door switches work (they kill cranking properly). Later I even removed and shorted the Brown-Brown and White-Black wire at the connectors to ensure switches can be ruled out.
I've tightened down both sets of battery terminals and verified ECU purple and yellow fuses on both engines (behind the screw off round cover). I also tightened up or verified any ground I could find on the engines.
Considering both engines are experiencing identical issues, I think I can rule out ignition coils all going bad, both ECUs dying, etc. I drove the boat home 2+ hours without transom tie downs (owner said they were not needed) over twisty and bumpy mountain/country roads. I'm starting to think somehow a wire or connector came loose, like a shared ground wire, preventing the ignition system from creating spark at the plugs?
Does anyone have any advice as far as what I should try next? And advice would be much appreciated. I'm running out of ideas and it's killing me not being able to start and use my new boat.
Lanyard is bypassed by unplugging it. do not short anything to bypass.
If neither engines are getting spark the first thought is the lanyard. You need to figure out if it’s supposed to be normally open or closed. The cleanout hatch switches are out of the equation, they won’t let the engines crank.
Thanks for the quick replies! I ended up figuring it out before reading your suggestion, Beachbummer. And you were absolutely right, I had shorted them thinking they need to be grounded but it's obviously the opposite because the engines fired right up after I separated the wires. What a waste of many hours tracking down loose grounds, other sensors, etc.! :rolleyes:
Now I'm dealing with the port side engine overheating. I'll probably create a new post for that after taking out the thermostat.
Right on..
Lots of threads on here about over heat and solutions.. use the search engine and you will find your results a lot quicker than waiting for people to respond to your questions.
All my overheats have been related to low water pressure on land, and debris in the pump while on the water. Make sure there is no cavitation/debris on the pump, no matter how small, if the pump is not well loaded and pushing water, the cooling water cannot reach the engine.
Any overheat more complicated than debris in the pump can greatly benefit from a search as suggested by @FSH 210 Sport
Best of Luck!
Thank you! I've been using the search a lot, but ended up figuring out on my own that one of my thermostats was stuck closed. I pulled both housings off and compared the two thermostats. Lots of corrosion and calcium deposits in the thermostats as well. I was going to post photos later in a new thread to see if people think I can reuse the housings.
Weirdly the thermostats still allow some water flow when closed
If the housing seals well to the point no water is leaked into the engine bay... I would try to reuse.
