2016 yamaha 190 fsh diagnostic trouble code list
montemichini
Hello all i have a 2016 yamaha 190 fsh center console boat and get the check engine light occasionally when I go to the engine diag screen i get the following code see pic for details. "yamaha trouble code 76 52 1902" i am looking for a way to find what this code is if there is a list of codes somewhere
Hi montemichini, I am having the same issue with the same year/model boat. Were you able to find a solution?
Unsure if is relevant but the issue only happens if the Start battery is turned on before the House. If the House battery is enabled prior to the Start the engine light/error/beep does not come on.
I think you found a solution!
