FSH 210 Sport
- Tranquility Base
- FSH Sport
Looks like the OP has not been around since July of this year..
Did you finish your dvsr modification to energize off an ignition hot?
I got a pm from a member the other day who is using a Battle Born 100ah battery as a start battery. BB says no to this but so far it has worked out well for this member. I also read on here recently that the starter motor draw from one of our engines is around 150 amps which is far below the BB BMS cut off level.
I’ve been running a 9ah anti gravity LiFePO4 battery in my dirt bikes for years now and they work great. As stated in my other thread our charging systems are well suited to using a LiFePO4 battery as they are always at full output.
