2023 222SE fuel percentage gauge
Surface-interval
212SD
My percentage gauge seems to be calibrated for a50 gallon tank instead of 70. It hit 0% when I used about 50 gallons. I’m at 53 gallons used now and plan on burning it on down as close to 70 gallons used as I can. Is there a way to recalibrate the percentage gauge to be accurate with the 70 gallon tank?
OCDoug
Ocean City, MD
252SD
the connext might be set for a different model. Mine was missing the shower button and I found the software was set for a 255 which does not have a shower. That was an easy fix. Quick software model update and I was set. Just my possible thought on what could be wrong. There are plenty of intelligent folks on here that should chime in.
Surface-interval
212SD
Thank you Doug, kinda what I was thinking as well.
Tranquility Base
Sometimes just running the tank down and filling it back up can correct issues with the percentage gauge.
Try this,
Try filling your gas tank slowly until it is full.
Go into your connext screen and re set the fuel used gauge, and your percentage gauge should read 100%.
Then run your boat around, burn a half tank, then compare the fuel used gauge to the percentage gauge and see what the results are.
Surface-interval
212SD
Thank you, I’ll do that first.
anmut
Just an FYI, these gauges are noxiously out of whack - the easiest way to deal with fuel is to fill up regularly. For me, it's a stop on the way home, so anytime we want to go out, we've got full fuel.
Tranquility Base
As a fyi, I have found my “fuel used” to be accurate to within 1/10th of a gallon, all the time. I use that so I know how much should be going into the tank.
anmut
Good call!
Surface-interval
212SD
I agree with both of you guys. I’ve been going by fuel used and also fill up after almost every trip that’s why it’s taken over a year to really notice that it’s definitely set for a 50 gallon tank. I got down to about 45 used and got the low fuel warning and light. Pushed it to almost 54 used now and I’m going to keep going to close to empty. It’s more annoying than anything.
Sherwood
Mine gauge has always read heavy.
Now appears to be getting even worse. Today the gauge said 49% and I put 33 gallons in 50 gallon tank.
