Liveto99
- New York Hudson Valley
- FSH Sport
I did not get back to it yet I’ll try tonight.
No need to remove the bucket cover. Just push em right though into the bilge. There is a washer on the inside as well. Once you push them through it gets easier. The socket that I use is an O2 sensor socket. You should of been able to get one from your local auto supply. Works like a champ. Have done 6 cable replacements, including mine to date. Just helped someone last night local as well. I bought 1 off of amazon, and then got another from Auto Zone. Since I lost my first one, and now have found it.
I would grab some debond or other silicon/adshive solvent and while you are waiting for the socket, get some on the silicone inside around the cable and washer where it comes through the hull. Good time to take care of your clean out tray and if you have a marine store around of have one, a second bilge pump down in the bilge. Just some thoughts.
Long as you have the nut off it should be good to go. You can try soaking the around it with DeBond a bit. Then rap the end of it with the hammer to push it through.
Did you ever get it? I think I had trouble there too, but it was a couple years ago so I’m not remembering details.We're stuck unable to bang the cable through to the bilge side. We've removed the nut and washer from the transom side and removed all visible silicone, but no amount of pressure, tapping, or flat out banging has loosened the cable assembly.
