- Knoxville, TN
- Limited S
That is a beautiful install!!!!!
Removing the seat back is simple. The screws that you see and pictured above are for brackets that don't get removed. The seat pushes down on them and hangs on them. The screws that you will need to remove are at the bottom of the cushions from the front side. You will need to push up a little on the bottom of the cushions to see the screws. Once you remove all the bottom screws, you will simply push the cushions up off of the top brackets. Reinstalling is just the opposite.I positioned the amp mounting board under the helm and not sure how to go about removing bow seat back cushion. The screws come through from the bow. I also thought about getting some L shaped brackets and mounting it to floor and letting top of board rest on the inside outer wall of the boat. I would think stiff brackets would keep it from moving.
Honestly, that what I love about this site....complete strangers helping each other out. I found it Odd yet comforting to know that I can come here and learn, read, stalk or chat with ppl with the same interests. I would have been looking around for ever to get that seat back off.
@MattFX4 I'm doing an amp board that will come up from the floor an attach to the helm area. It will have space behind it for the wires to run and also allow air to move around behind it all. I don't like the idea of covering all the behind the helm wires, tubes and limiting the access. I've seen a few installs that look amazing mounted that way though. I saw one that was amazing ! My other choice is behind the seat and I like that spot because it is up off the floor. So here I am again at a cross roads......keep me posted on your install. I will start mine next week as my tower speakes were on back order and they should be here by Friday
I have pretty much the same setup, minus 2 speakers, and I have the same hissing sound at low volume with mine also. Haven't had time to investigate it yet. If you figure it out, let me knowMade more progress Friday night. Was up to 3 am finishing this job off so I could enjoy the weekend. Got the 8 mx650's in, and the amp. Will have to do sub later.
All I have to say is wow. Just wow. It sounds incredible. I'm currently running 8 JL mx650's off of a JL m800/8v2 amp, and the factory tweeters off the head unit. Night and day difference between now, and the factory stereo. We have no issues at all hearing clear, crisp music even at full throttle. It gets pretty loud of you crank it up! The speakers have pretty good bass as is, and could get by without a sub. I can't wait to hear it with the sub. My only complaint is I am getting a hissing/whining sound when the volume is down low. You can't hear it once music is turned up. Will have to figure that part out.
