M@D-M@X
- S. Fla.
Hi everyone,
I've owned a 07' AR230HO since new. Unfortunately due to life changes & Covid, the boat literally sat covered for just over 3 years and I know some of you are going to flip.. Last week I started a plan to get her back in the water and back in shape. Although this boat has always been in the ocean, I always tried my best to keep her in shape with corrosion control and thorough flushings. My biggest worry was obviously the 3 year old fuel. The boat was always fed 87 pump gas, since Rec.90 was not readily available but I did treat every fueling with Sta-Bil (marine). At the gas cap the fuel still smelled like gas and not like turpentine or varnish. I figured since I've always used synthetic oils and always replaced the plugs and the gas doesn't seem to be that bad, I decided to give it a whirl and start her up.
With a new battery, she only clicked wihout turning the first try, then after roughly 30 seconds on the starter and to my surprise both engines crancked.. Initially it was a rough idle lasting about 15 seconds, then smoothing itself down to a normal idle. A mechanic/friend told me to look for pinging, in which case means that the fuel was badly degraded and would need to be replaced.
After this initial event, both engines instantly turn on and idle smoothly. I ran them about 5 mins each, trying not to rev them high since I'm still waiting on the plugs, oil & filters to arrive. There's a possibility that I haven't made it past the storm unscathed but as of this moment I'm truly impressed on the outcome so far and the reliability of the Yamaha MR1 engines and maybe something about Sta-Bil as well ?
I'm open for suggestions and obviously criticism but more importantly tips on several upgrades and replacement of items in need.
As of now the upholstery might hold up to 2 more seasons, I'll need to replace the helm's rocker switches, since they're faded. I've contacted SeaDeck for some info and also looking into the possibilities of getting the Reverse Thrusters kit.
