jacoviii
- Independence Mo
- 255XD
cool
Using 2 short ones and cutting them down the flange on them is a little to thick to fit in the clevis, I ended up cutting down a longer one and it is pretty good. I have 98 left if anyone needs a few I can drop them in an an envelope and mail them to you, just private message me your addressSo I found a part that might work for this from McMaster-Carr. I bought 2 different lengths to try. 100 pieces are $7.00. I may have to trim them a little to put one in the top and bottom. or just use the longer one without a flange on one side.View attachment 127119View attachment 127118
@bthessel, what is the inner and outer diameter of those?
Molded nylon should last longer than the printed PETG that I am using.
Have you replaced the full length blue ones with a white one that is different material? I haven’t installed the blue ones yet, but if the white ones are superior I’d like a couple of those. Thanks. I would prefer the shorter ones so I have a flange on the top and bottom. Thank you!I added a half length version of the PETG steering bushing so they can be used from the top and bottom.
This is the full length version which will only have a flange on top - Steering Bushing 4 Pack Full Length
This is the half length version which allows for flanges top and bottom - Steering Bushing 5 Pack Half Length
I spent entirely too much time in Fusion 360 designing these, and it took about 6 design iterations to get the correct size. I also fought with my printer for enough hours to have spent the extra money on a Prusa MK3S+ that I wanted instead of this Ender 3 V2 but we’ll save that story for another time and I’ve just decided I hate PETG and will use PLA for everything. It takes less time to print new bushings and swap them than I spent trying to print PETG. Anyway, I recorded a video showing the difference in play. Port side has the original garbage bushings that are too small and thin. The starboard side has the 3D printed bushings in the top and bottom.
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
Stock bushings vs. 3D printed
Glad you got them to work. I tried with a 0.4 mm nozzle initially then dropped to a 0.25 to be able to print the barrel section with two walls. I also went through several revisions before getting it right for my boat then made additional revisions after sending them out to others.
I would be curious to know how long your PLA prints last. There is no significant heat exposure so that should not be an issue.
I hadn’t even considered a smaller nozzle since I’ve had such great luck with 0.40 mm. I’ll check my slicer but I have set to print 2 walls and I think my design ended up 0.67 thick. I think one of my iterations was 1 mm thick but that wouldn’t fit in the steering hole in the jet nozzle.
One version was just barely too thick of a collar and I had to pry it out which wound up separating the collar from the barrel so I’m interested in how long they last too. I boat in brackish water so we’ll see how long they last as I haven’t read much about PLA and salt. Either way if they fail it won’t be a big deal at all. I’m trying them out today. The funny thing is I didn’t even consider the steering slop a problem and just accepted as “that’s the way it is” until I read this thread. Then every time I drove the boat I was aggravated. ?
Of all the stuff I’ve printed, these were probably my favorite. Tweaking the design and popping a new one out in four minutes is awesome.
I just had mine apart to do steering cables again and they did the exact same thing--holding up really well other than the flange coming off on the top on the starboard side. I'm pretty impressed with PETG thus far. I've had it dunked in brackish water for hours under pressure from the water movement, left some in the sun as an umbrella grommet in a patio table (direct sun), used it to make parts that need a little flex to snap into/over something--great material.In 2020 I installed the first prototype PETG bushing on my starboard jet. Last night I replaced it and the metal bushing on the port jet with well greased half length PETG bushings. I did not think that two flanges would fit but they did very tightly.
I was happy to see that after 2.5 summers of use the first PETG bushing was still functional. The flange had separated from the tube but both parts were in place and doing their job.
The steering feels really good with the new bushings installed.
View attachment 200867View attachment 200868
The funny thing is this part was the catalyst for me to move on from my Ender 3 V2 which had just ended the 'honeymoon phase' where it worked great for a few months and then didn't. I couldn't get it to print these bushings to save my life so I upgraded to a Prusa MK3S clone which was just great. I'm curious how my Bambu Lab X1C will do with parts this small, I may print some tomorrow while the steering components are still loose to see how it does.
