Anchoring video
Tranquility Base
You work less than I do! lol
Also note he is using a slip-ring, which are absolute garage. A true fluke is much better.
I might “work” less than you right now…
I‘ve got a slip ring fluke that I’ve had no issues with and the slip ring has made retrieving it on a couple of occasions as easy as possible when it refused to come out straight up. I do like how some attach the chain on a non slip ring danforth to its base and tie the chain to the shank with tie wire / ty wraps so in the event the anchor becomes stuck the chain can be freed from the shank by breaking the tie wire so the chain then will pull at the base of the anchor backwards.
Good basic video. Am I the only one that was cringing every time he pulled on the chain or rode, and it was gringing/rubbing on the boat.
Good basic video. I'm I the only one that was cringing every time he pulled on the chain or rode, and it was gringing/rubbing on the boat.
Agreed… at least it was stainless chain… it doesn’t mark like galvanized will. But still…
We only use our Danforth as a 2nd anchor off the rear, boat it has a coated chain.
We have both a 19 land 13 lb box anchor that uses our primary.
While the 19 can be finagled to fit on our ski locker it is a PIA, so we have gone back to the 13.
