Another Stoltz Roller Post
212s
1000 Islands
C'Mon...... Get the Guides, 1" max from side of boat. Game changer for loading, especially for the inexperienced, in a wind, chop or current.
Power loading is prohibited in our area so guides are of no use to us. Plus I'd rather hand-load because it guarantees no scratches, centers nicely, and we're usually 2-3x faster than all the bass boats with guides trying to get on the trailer. We're usually in the staging area getting ready to drive off when they're just pulling out of the water, and they arrived at the ramp before us.
:D
212s
1000 Islands
and put on safety chain and pull out to load staging area.
You should put on the safety chain before you pull out of the water and up the ramp. If you have a winch or strap failure, the safety chain will keep your boat from landing on the ramp...that would not be a good day.
drewkaree
West Allis & Fremont, WI
Last time out was much better. I had moved my winch tower back 3". So the tongue weight is better, and it does align up better on the bunks. But like you said, the wind can push it off center very easily, unless you have someone back there to hold it.
I cannot remember who did this, I think it was @Ronnie, but they replaced their bunks with longer boards, and it helped them with "catching" the trailer sooner. Sounds like it might be a help to your situation.
RobbieO
Sacramento River Delta
212SE
:D
I use the guides to help me load/unload when I'm by myself, especially when it's windy. They also help me when backing into my storage unit. I don't plan to ever power load my boat, on or off. Like you said, improves your chances of not damaging your boat. I'm on board.👍
ZGhost
Minneapolis, MN
Power loading will eventually damage your car transmission. I slowly pull up until boat stops on its own, then crank it up.
HangOutdoors
Royal Oak, MI
:D
No one indicated they were power loading...... There is a difference between power loading and gliding your boat on the trailer through the guides and while your engines are off. Haven't seen anyone indicate that they are actually Power Loading like the Bass Boats, which is ignorant and lazy and destroys the area around the ramps. Using Guides and Power Loading are different things and should be. I don't have issue with scratches or centering and also am extremely quick and efficient loading and unloading boat. Additionally I will guarantee in a good cross current or wind the guides make it much easier, especially when you don't have help.
HangOutdoors
Royal Oak, MI
My boat is still over the water and I only put on the safety chain after the abrupt stop to snug the boat. I don't want the chain smacking against the boat. Once snugged the safety chain goes on.
KCAR250
Power loading will eventually damage your car transmission. I slowly pull up until boat stops on its own, then crack it up.
How does power loading damage your vehicles transmission?
ZGhost
Minneapolis, MN
Your boat will push the car forward while its transmission gears are engaged in park. Puts repeated undue stress on the gear teeth. Ever feel how hard it is to shift into drive while the car is parked on an incline? it’s because there is a load on the gears. Same principle.
RobbieO
212SE
I am about to install my new roller and was wondering if you all left the metal cap on the end of the new roller?
Are you installing a Stoltz roller or the same one shown in picture? If installing a Stoltz, there is a washer for under the head of the new bolt, and another one for under the nut. I cannot recommend the one you have pictured. My trailer came with that roller and destroyed my gelcoat.
Pokes1789
I installed a stoltz I was asking in the post if the metal ends of the old one need to go with the stoltz. The didn’t fit so I used on the washers 👍🏻
RobbieO
212SE
Okay cool ! Sorry, I misunderstood!
Ericd
Illinois/Florida
How do you trim 1/4”-3/8” off each side of the center roller?
I tried a table saw with general purpose blade. Didn’t cut straight and gummed up the blade. Stopped pretty quick so it’s still salvageable.
Suggestions appreciated
RobbieO
212SE
Here’s where I got mine:
drewkaree
I
Belt sander. Sand off what's necessary
Ericd
Illinois/Florida
I think I need the deeper-v for the 210 FSH and I have the 4” just need to cut it down. Thanks
Ericd
Illinois/Florida
[/QUOTE]
Will give that a try!!! Probably makes a mess…Thanks
drewkaree
Yeah, it will, but it's the easiest way to get consistent results with a flat end to the roller. It also goes a LOT quicker than you might think, so be careful. I did my old blue roller, make sure you're outside, the static cling will crap up the siding on the house for several weeks if you aren't paying attention - ask me how I know 😂
