CrankyGypsy
- Tampa, FL 33615
- SeaDoo
- Challenger
there are ten bolts attaching the large "collector" to the manifold. i have eight of them completely out (#9 and #10 in diagram). one that the head snapped off and another that seems to be fully unscrewed, but is still stuck in the collector. i also removed the four bolts that mount the exhaust to the injector side and the bolt that attaches the collector to the case (#2 in diagram), so as to remove it as an assembly. update: i recently learned i could have just loosened the large clamp on the rubber elbow to expose another clamp that secures the collector and elbow assembly to the large pipe rather than removing the four bolts below the injector that secure the pipe.
i can't seem to get any separation whatsoever from the manifold or the gasket. even hitting it with a hammer feels like it is still bolted on solid. i've tried heating the parts a few times with a torch, but no luck.
anyone have any experience here?
(success at post #14)
