Battery powered and hard wired LED tow point mount
I’m expecting all of the parts to arrive this week. Here is the list I have so far.
User Name Option
drjames1107 3
Craig 3
Cowboy Casey 3
Gthunter5 3
MDBodnar 3
Gumbeaux 2
a-mac397 3
steined 3
0627devildog 3
In addition for all of us who don’t have a 242 I can include the ¾” grommet LED. Choose your color Red, Blue, Amber, or White. They are all clear when off and I can include it for $25.
@jeremy0011 have you seen the tow point kits on the New Scarab Boats? They look very similar to your design, might be something you want to look into since the Scarabs are new and you've been making these for a while now. I have a pic on the thread below.
https://jetboaters.net/threads/scarab-judgement-day-lake-lanier-may-30-31.2008/
It looks good; the only think that I have created is the mount and the method of attaching it to the current towers. The LED is off the shelf and you can also find them on the $130k Super Air Nautiques that I was drooling over this past weekend. Interesting that they would include a tower anchor light but not a permanently mounted navigation light.
Ok good news, just making sure we look out for each other!
User Name Option
drjames1107 3
Craig 3
Cowboy Casey 3
Gthunter5 3
MDBodnar 3
Gumbeaux 2
a-mac397 3
You forgot me for #3 :)
Put me down for an order on Option # 3.
Thanks for the answers. I'm in for the #2 option!
Where does the 3/4" grommet led mount?
Under the tow point in the tower tube as a 3/4" hole is required there to fish the line through.
The 242's have a Grommet LED in this location already so it's not needed, but everyone else will need to drill a access hole in the location shown below. You will want to drill this hole as close to the rear tube as possible to make drilling and pulling wires into the rear tube easy. You can then put the grommet LED on a second switch and light up the boat with it. I chose red to not mess up my night vision while out at night. It works very well and Looks awesome.
It would be useful to have a push button led so you could turn on/off. Maybe some kind of opaque cap would suffice in the event you wanted it off/blocked for some reason.
I added a second switch to control it independently. But I like your idea on the push button LED I wonder if they make one that’s a grommet LED.
My tow point light kits will be ready to ship out tomorrow Friday the 13th. I have sent PM’s to all of you on the list with payment information. Let me know if I missed you. If anyone else would like a kit I have several left.
Can anyone link to a tower wiring thread to assist with the install? I have searched here without success so far.
I installed my light and adapter but havent wired it yet. I'm having a hell of a time getting the hole drilled in the tower tube, inside the flat area where the tow point mounts. I think I drilled the access hole too far away so I may need to just cap that hole and try again on the top side. If you drill a hole on top make sure you seal the plug with some caulk or your tower will eventually fill with rain water.
Did you have any problems with this?
A shop vac should pull a bit of frayed string through to get you started pulling wires.
What kind of string we talking about? Kite string maybe?
I made a small tassel with some yarn.
I need to stress the importance on drilling the ¾” access hole as close to the rear tube as possible or you will not be able to drill the second smaller hole into the rear tube. I made this mistake and after several hours of filing the inside of the first hole I was able to drill the rear tube. Had I been another 32nd away from the rear tube I would not have been able to drill the second hole. Here is a picture on the proper placement of the holes.
