Chrisbert
- Central Texas
- 252SD
2022 252SD
Last 2 trips out my engines were very slow to turn over, and on my recent trip this weekend I got the battery alarm. I saw my "house" battery was around 10.x volts at idle and "start" was high 11.x volts. These are the originals installed by dealer in Spring of 2022. I keep them on a NOCO, but given our Texas heat it's time to replace them. Way cheaper than a tow.
That said, it looks like my dealer installed two cranking batteries. Although they have a different looking label they have the same specs on the Interstate site. The questions I have is should have one cranking and one deep-cycle (house)? Are there comparable AGM batteries that folks here have used?
Thank you!
Thank you!
