Welcome to Jetboaters.net!
Today ran across a rock and basically tearing off the keel at the pivot point, nothing left, where do I find the whole assembly for the AR190? I can't find it on any parts diagrams.
The diagram @itsdgm posted appears to be for the 21' or 24' boats because the rudder doesn't attach on a 19' boat with that little plate (item 19 on his diagram) that goes off the actual keel of the 21' and 24' hulls. 19' boats don't have a full length keel made in the hull but rather in the ride plate.
This is the linkage and rudder assembly for 19' boats...
You don't have the same boat, show pics of your damage to help, or speed up the process to help you obtain a good/correct answer. If your boat listed in your profile is correct, you don't even have the articulating keel, that came out in 2019, if I recall correctly, so pics of your issue are definitely a necessity. If your boat listed in your profile is INcorrect, you need to fix that to help us help you, and still...pics.
