Welcome to Jetboaters.net!
You are definitely on the right track now! Keep sharing status and I am confident everyone can keep you there to get you back in business. One step in the wrong direction can be game over; but it sounds like you dodged a bullet (or two). Yeah and good job.
Amazing how the members here are quick to respond and stay on to offer advice. Most of us have all been there, one time or another, so I'm very appreciative of this group!
If your air filters are wet as you mentioned you do have water in the engine. Take the previous advice about removing the spark plugs to clear the water out. I hope it was fresh water.
The MR-1 Engine can use 10w40 Oil. Since you need an oil change yesterday, buy 4 gallons of the cheapest 10w40 you can find, and once you swap it a few times and get no water in the oil and run it for a couple of outings, you can change it again for a better oil in a few weeks. I normally use I use 10-w40 Castrol High Mileage on mine, since mine is 11 years old.
These filters are normally available at any auto parts. Any should do Bosch 3323 Premium FILTECH Oil Filter
Fram PH6017A
Wix 51358
Mobil 1 M1-110
They are equivalent filters and fit the MR-1 just fine. I happen to own a 2008 Honda Pilot, and it turns out the Pilot and the MR-1 engine use the same filter, so if they don't have either of these, tell them to find one for the 2008 Honda Pilot and that filter should fit too. The Bosch filter is very nice and usually available locally.
Don't wait for stuff in the mail. Do you best with the parts locally available so you can get the boat started and running today. Your auto parts store will get you going.
I’d start by getting out what you can while it’s cold. Fill it back up and keep checking the oil as you run it. Any signs of cloudy or milky oil you want want to immediately change the oil. New oil filter once you get the engine warmed up and can get all the oil out. And keep repeating until you’ve done a couple complete changes. Then get it on the lake and run it hard while keeping a close eye on the oil.
I’d change the plugs once you get it warmed up today and then maybe again after you have it on the lake.
The other thing you maybe could have done was put a halogen shop light under or near the oil pan for a few hours to slightly warm up the oil... or one of those seedling germination mats overnight... Not a big deal either way at this point.
Fram PH6017A
Wix 51358
Mobil 1 M1-110
I am not aware of a widely available air filter. If it is wet still, run without it for now, much better that letting the boat sit. If it's dry and clean, you can use the old one.
Swat, if Im going for over $100 for a oil pump its gonna be electric. JM the reason I posted that oil extractor was the potential amount of times you might have to change the oil in the next week. Being electric you just attach to your starting battery and let it do its thing. Its ideal to have the oil warm but in this instance I would remove the contaminated oil and run it warm with the new oil.
I hear what you are saying but until you use this one you will not believe the difference. Twice as fast as electric and gets more oil out. I was a non believer also.
Most, if not all, the electric” ones are 12v so you just hook it to the vehicles battery. Which I guess would be a pain for a push mower but you could always use a jump pack.
I like that manual/shop air one but my new to me Volvo takes 8+ quarts. Otherwise seems the best of both... powerful and portable.
With the 12v ones jabsco makes one that is reversible for a little extra money. Seems worth it for emptying the bucket.
Reason for my choice is I used to have a tech come and service my boat and when he did oil thats what he used. I pretty much only use it for the boat so I always have power for it but as stated except for lawn mowers and those types of devices a 12v source is usually near by. In the past I had manual ones and the electric was much easier.
