DRIVE Neutral Steering Assist - 2024 and newer
Madman
Sun Prairie, WI
252SD
I bought a new ‘25 252SD and went the SD model because it was equipped with the DRIVE system. The hope was that the advanced steering system would make low speed maneuvering easier for new drivers and make them comfortable with taking the boat out on their own.
So the problem I’ve run into is a feature called Neutral Steering Assist. As long as the boat is in gear, it responds as you’d expect. Turn the wheel right the boat turns right. But soon as you shift into neutral, the controls are reversed. Even idling in neutral, if I turn the wheel right, the bow swings left, which is not what you’d expect.
On my ‘10 242, whenever I sitting in neutral and idling, the position of the steering wheel had no effect and the boat just sat there. If I was slowing down as I was coming up to the dock and shifted into neutral, the boat would pretty much maintain its heading and turning the steering wheel had no effect.
The issue is the same when using the paddles, too. Turn the wheel slightly right and squeeze paddle, the boat moves forward and turns right. Release the paddle and the boat immediately changes directions.
I’ve read through the manual and there is one sentence that tells you how to turn it off, but doesn’t explain what it is. I’ve been trying to turn it off. I’ve tried doing a system reset by disconnecting the batteries X3. While that fixed the issue was having with the depth finder, the boat continues to respond the same way.
Has anyone experienced this and/or found a solution?
‘24 252SD. I have the same experience. Have yet to find a solution, other than remembering to steer back to center or complete opposite when coming off throttle.
@TommyMcK has posted similar feedback.
You should include the pic of the manual that you put in the other thread….
Good suggestion because I know many of us probably don’t read the owners manual without a good reason! Attached is a pic of the only documentation I could find on this feature in the owner’s manual. It’s only one sentence under the DriveX Settings screen telling you how to activate or deactivate the system, nothing to explain what it is or what to expect. My understanding is that once the system is deactivated, the boat responds like earlier models, meaning that the position of the steering wheel while the boat is in neutral has no effect.
That is caused by the reverse bucket shape and how it shoots the water in reverse All my Yamaha p w c's do the same thing with my steering on the fins it does make it more Stable and easier to deal with as it calms down the movement of the hull when the reverse is engaged just remember to turn the helm in the direction you want the bow to travel rather that the direction you want the stern to go then you don't have to think about it . Jeffrey T. Walkowiak note how the handle bars are going in the opposite direction that you would expect them to go , same as a boat with the backward reverse nozzles I have one in slow motion but I am having trouble getting it to copy and post it is on my Jeffrey T. Walkowiak face book page though fro0m a few years ago my point was that the reverse buckets working backward are stabilized and easier to control as for the other items you mentioned I do not have that to contend with. Thanks for the clarification.
Please don’t take this as me being snarky when I say I’ve been driving PWC and jet boats for 15 years, but this is my first new boat since 2010. 15 years by no means makes me an expert, just sharing that I have some basic knowledge and experience.
I watched the video and noted he’s maneuvering under power. My boat performs as expected under power in forward and reverse. The problem I’m experiencing occurs when the remote levers are in neutral. With my old boat, with the levers in neutral, the steering wheel position had no effect on the boat’s position. It basically just sat there. With my new boat, idling with the remote levers in neutral (and neutral actually works really well on this boat!) turn the wheel right, the boat pivots left, turn the wheel left, and the boat pivots right. That’s not what I would expect, but that in itself isn’t the problem. The problem is when you move between neutral and forward or between neutral and reverse.
The issue for me is when launching and recovering, where I’m maneuvering in close quarters around other boaters and dealing with wind and current and people fishing from the docks. As an example, when recovering in Drive mode. I lightly squeeze the forward paddle and begin moving towards the trailer, making minor corrections when needed, but always squeezing the paddle. As I get closer, I recenter the wheel and release the paddle, which immediately puts the boat in neutral and now the controls are reversed. If I turn the wheel right, the boat pivots left. If I turn the wheel left to bring the boat back, it begins to pivot right. If I squeeze the forward paddle as the boat is pivoting right, the boat now swings to the left. This feature just makes recovery unnecessarily stressful and unsafe.
If I was younger, I might be better able to reprogram my mind, but that’s not likely! I really don’t understand the need or logic behind this feature. I think might actually love it if didn’t reverse the controls. It’s almost seems to be a programming issue where somebody confused their left and right.
The real problem for me is that I can’t get it to turn off. I’ve tried cycling the batteries off and on trying to reset the system, but changing the position of the Neutral Steering Assist button has no impact. I’ve reached out to my dealer and he wasn’t aware of this feature and says that Yamaha’s tech support doesn’t seem familiar with it either. From what I can tell, this feature only applies to ‘24 and newer Drive models. I know others have experienced this problem and seeing if they’ve reported the problem or can share a solution.
I can fathom some weird stuff but that right there is a bit stupid, more stupid that you cannot turn it off, the directional control should never change direction. As I suggested before, get used to using differential thrust, it is precise, reliable and you know what to expect when you are applying power when splitting the throttles. If you use no wake mode and raise the rpms to level 1 or 2 this will give you even more thrust and control.
The only time I have found that I cannot use differential thrust is if it is very windy, like 30-40 mph gusts, there just isn’t enough bite in reverse on one engine to be effective, in those instances I use both throttles together and the steering wheel.
This thread is linked at the bottom of this page.. especially read the post by @TeeNGee he shows a page out of his 255 FSH H model owners manual where it describes the operation of the neutral steering assist. To get the change in the menu to take, you have to shut down the boat and cycle the power off then on.. at least that is what I interpret it to mean.
Apparently @TeeNGee found this info in his service manual.. this is why everyone needs a service manual and reads it.
RTFM.
Yep, I saw this before and even tried the using that process several times to turn it off, but it didn’t work.
RTFM.
Agree 100%. I had one for my old boat, but they aren’t available online or in print for this one yet. I just looked and the ‘24 model is available. Since I have the 10 hr service coming up, I’ll probably do the 60 day ebook and see what I can find there.
Here is a screenshot of the Steering Assist Page from the 2024 255XD Service Manual. Only difference from the FSH is the "heading" of the section is DriveX Settings rather than Joystick Settings.
I have driven mine with this setting on and off and tend to leave it on and have learned to react to it. Remember there is NO Articulating Keel on a DriveX boat so essentially in Neutral while still having forward inertia there is NO steering.
I do have the Cobra Jet Fins (prototype unless Jeff says otherwise) on my Pump Nozzles and do experience better idle and slow speed handling. In putting the throttle in neutral I do get some steering but these are jetboats and thrust is steering..........
