Dual battery - Unknown ground wire to batteries
Robbie - Bama
2016 Yamaha 242 S
I just recently swapped batteries due to low/high voltage warning. When replacing batteries, I located a ground wire that was not hooked up before, but I can tell it had been previously. New boat to me and my dad, the previous owner can’t recall where it hooked up to.
Facts:
- starting battery has two 4-6 gauge grounds going to engine compartment
- house battery did not have a big ground, other than two for the amps and 3 smaller wires that all appear to be for audio system.
- unknown ground is smaller gauge (maybe 10-12g) and goes into engine compartment, into another larger wrap of wires.
2016 Yamaha 242 S
Facts:
How do you know it’s a ground wire ?
It was labeled inside the plastic wire loom. I’m curious as to whether it should go on the house or starter battery. Right now, the starter only has the two negatives going to the motor.
Well, all the grounds should be connected together….
Are you saying it doesn’t matter whether it is connected to the start vs house?
Yes because the start and house batteries grounds should all be tied together
So that’s a question that has been bothering me. Electrical is not my strong suit, but I know just enough to be dangerous. I don’t like how Yamaha wires the batteries and thought it would be nice to consolidate all the grounds. It would simplify battery installation, but I wasn’t sure if I’d need to isolate each battery with separate buss bars. I’m guessing that I’d need to connect the negative from both batteries to the buss bar?
you want a common ground system......if your going to be cleaning up the wiring, I would use a busbar and connect both batteries to that along with all other ground connections. alternatively, you can connect all grounds to either battery and then connect the two battery grounds together.
That makes sense and appreciate the confirmation of what I thought. Sitting here and thinking about it for a minute, I realize the battery’s negatives are already connected, so that leaves me with a question of how determine the proper size of the bus bar. Knowing bigger is better and the max draw will be when starting an engine, so would a 250 amp bus bar be sufficient or how would I test to determine the draw on a battery?
250-amp should be fine......if you wanted to confirm, you could try and find what the battery switches are rated for and use that as a minimum.
