dgfreeze
- Central Ohio
- SX
How much weight is too much per square inch for the floor in my battery compartment? I’m thinking about adding a third battery to be safe with my new stereo system, but if I do that, I’d like to rearrange my current batteries, and add the second one by fabricating a stainless “rack”, and putting the third one above the two on the bottom. My primary concern is putting too much weight on the floor, and causing issues there. It would be braced at the top, but the top brace would not be load bearing, just bracing from sway and wiggle. Here are a few rough sketches of what my mind is thinking. It would allow me to relocate my switches and some other stuff from the walls to this frame, and the frame would be able to double as a built in buss bar.
