You are probably right, those rule probably apply to hostile environments, but they still have to follow. But common sense suggest, he can just give coordinate for rescue and follow the other plane lol. there is nothing much he can do for the other pilot anyway.In an ejection scenario, standard operations for the wingman (flight lead) is to get eyes on the survivor's chute and orbit their position to effect a SAR operation. The aircraft crash site is a distant priority at that point and all efforts are directed at recovering the pilot and/or crew. The transponder not being active is not unusual if the aircraft was operated in formation. ATC mostly prefers a single transponder track to identify a flight (usually lead squawks for the flight) in standard formation or it can make their system get excited about two to four tracks directly on top of each other (think impending mid-air). The radar paint track is not very precise and probably not very low altitude capable either. ATC may be able to review tapes and find an errant skin return that drops in altitude and eventually off scope. Also aircraft with stealth features are often operated in friendly non combat environments with an extra beacon or external store to offer a return for ATC, although transponder is the current approved method. Lastly, inadvertent ejections are rare, but have occurred in the past especially with newer aircraft models. I remember a T-6 Instructor punching himself out while sitting on the ground at EOR. It was totally his mistake but was blamed on bad design since he was an O-6 (but ironically the design didn't change and it hasn't happened again).
I would guess that the aircraft is most likely in the drink somewhere and they are hoping to find some floating wreckage, but who knows, stranger things have happened. Just thankful the pilot is in good shape.
Again, just my 2 cents, its probably only worth half that.
A law enfordement helicopter just went off the Flight tracking near Stuckey. Hopefully they found it.
@jawsf16 if you get punched out are you still allowed to fly military?
Well it looks like they found it Williamsburg county SC. Should be interesting to hear more, if we actually do get all the facts,
Looks like that man got shafted…Here is a description of what happened and what ensued for the pilot.
Marine pilot loses command after ejecting from F-35B that kept flying
Col. Charles "Tre" Del Pizzo said the commandant of the Marine Corps ordered his removal from command after reviewing the crash investigation.www.defensenews.com
