Jmiller912
- Ohio
Thanks everyone. Looking forward to the next nice day. Ordered the cobra jets today so hope that helps.
I need to remember this. I've docked (my slip, fuel, and restaurant) about 5 times this past weekend (first times out) and I know I need a lot more practice...and I am real nervous about doing it alone but I will have to at some point soon. Sorry to slightly hijack the topic!
Thanks. I may go with the 8.5”. Our hulls are difficult for perfect placement. I have the storage room for now.Overkill is never a possibility with fenders. Oversize and not fitting where you store them--that is a different matter. If you have the space to store them, the bigger the better. No question.
Thanks for the heads up. I put a plastic Danik hook there all the time. Now I’m afraid to look. I did hit the dock with that fender once. I have it horizontally.Don't fret it too much...we got the new 2020 boat and although I didn't hit the dock, I put a plastic Danik hook on the rear cleat at a busy dock and didn't realize it would rub against the silver pinstripe above the rub-rail. Oops...no big deal...a little heat and it's good enough for now. One day I'll probably pull the pinstripe off the boat.
Where can I purchase the decals (Large ones on the sides). After my tie-up for a bite to eat I noticed the boat was hitting the opposite side and found BAD dock rashThe Yamaha decals are paper thin/cheap and scratch easy....Nice part they are cheap to buy. If it’s bad enough just buy new decals and change out when your ready to sell it.
Thank You.. Just put in my order... Any tips on how to remove that decal ?Try here. Not sure which you are looking for. 2018 Yamaha AR240 HIGH OUTPUT (SAT1800AT) Graphics & Mats | Yamaha Sports Plaza
Hot sun and a hot hair dryer, or a heat gun. I used a heat gun to remove mine on a cold day.
Surely you mean wax (After?) I clean the old residue off and reapply a new decal ?Add some plastic razor blades and adhesive remover (Goof Off, Goo Gone, etc). You'll wanna wash it really good afterwards as well, I'd go with Dawn for a stripping wash, and plan to re-wax everything afterwards.
Thank YouIf the adhesive is still felt on the painted hull good ole' WD 40 is a great solvent for removing it and then you'll have to wash it off.
For the install of the new decals: Bottle of windex/glass cleaner, painters tape if doing solo, old credit card/small squuegee gift certificate, pencil and maybe a third hand. Super clean the area, layout the new decal where its supposed to go and mark the strategic points with a pencil. If the backing paper wont allow the layout then fully coat the layout area with the windex/glass clean or even warm soapy water and stick as much of the decal on the wet surface as you can. Once in position use the credit/squeegee to push/pull the fluid out from behind the decal. Done properly the decal adhesive will grab fully and then you can continue unwrap the remaining backing paper, soap up the remaining areas and repeat till the decal lies flush and tight on the surface. If the decal is small enough you can wet the whole area and affix the decal on the slippery surface and move it into position and then squeegee it out.
Good Luck!
