- Georgetown, IN
SO, there's a LOT of chatter here about converting from SLA-AGM batteries over to LiFePo4 batteries. Best I can tell they are a direct replacement, and work just the same as the SLA batteries they are replacing, with the added benefits of being lighter, and capable of handling more charges before becoming unusable. All great things.
I'm not working on a boat though, I'm rebuilding my youngests electric 4-wheeler. He has one of these: Dirt Quad - Razor This thing has (2) 12V 9Ahr wired in series to provide (I think) 24V and 18Ahr of capacity.
Existing packs look like this:
You can see one is failed and bulging. Probably why it quit taking a charge.
I put these standard SLA "Mighty Max" batteries in it two seasons ago, and they barely survived the first season, and he didn't ride it much last year. When I compare the SLA batteries to the LiFePO4 batteries the LI ones have a bit more runtime, but otherwise are the same voltage, shape/size/configuration.
These are the batteries we have now:
These are the batteries I'm looking to get:
I like the slightly longer run time of the new batteries, and honestly even at DOUBLE the cost, these are still under $100, so they seem like a good deal. As best I can tell they'll just bolt right in and work like normal. Would be nice if they would continue to hold a charge for longer than a season, and that would almost instantly generate the justification for the additional cost.
Am I missing anything? Will the Razor's existing battery charger handle these? If not, where do I find an appropriate 24V charger? Do I need to have any additional considerations for fusing or power wire sizing? Any random thoughts to share?
