Ronnie
- SF Bay Area
- Limited S
The ram mount for the garmin is attached to a ball which is mounted to the wall of the dash/console that faces the combing box (so opposite my cruise assist switch). When the arm is removed you can't see the ball without putting your head into the combing box / throttle area. The hard part about that mount was screening it into the wall. I drilled from inside the helm toward the combing box because the drill wouldn't fit the other way. It's i pretty slick set up since the mount is hidden and the leads store in the combing box they come through.
