Help! Buying used boat but I've got a concern
caphilli
Took a test ride on a 2019 AR 190.
61 hours - everything felt great. We were on the water for about 30/45 min.
2 things that I noticed that are concerning:
1) When we took the boat out of the water and opened the 2 drain plugs and drove away, a good amount of water came out of them. The owner says that's the engine draining. But I'm not too sure. (Noob with jetboats). Is that the case? I can't estimate how much. It wasn't a faucet, but it was at least a couple cups.
2) When I crawled under the boat I noticed that one of the metal grate bars at the intake was broken off. How common is that? I'm guessing it's a pretty big deal. I called a yamaha dealer and they said it'd be ~$450 to install a new one. Does it need to be replaced before the boat is taken on the water? And Is it possible to do yourself? If so, where could I order one? Thanks!!
I don’t think 2 cups is a lot. Just make sure there’s no hull damage.
Grate is more important. I replaced one on my sea doo speedster, wasn’t that hard. Have not had to do it on my Yamaha.
I haven’t checked but I’m sure you can get the grate from Babbits or other vendors.
I would take a flash light and look up inside the intake tunnel where that grate is broken off and make sure the impeller and the wear ring (sleeve around the impeller) is not damaged.. while you’re at it look at the other side as well.
water doesnt sound like a big deal. A Couple cups could be from rain or 500 other things...
Missing Grate on 2019 would be a no-go... unless they replaced to before purchase, without additional costs.
That water draining from the plugs is not from the engines but a few cups are no big deal. Mine drains a couple gallons every time.
Replacing the grate would be easy. How it got broken is more concerning. Check all the fiberglass out as others have said.
I bought a seadoo with a missing intake grate tine. When I got it home I found the tine wedged between the impeller and stator. Thankfully it didn’t do any noticeable / performance robbing damage to the impeller or pump. The dealer price of $400 probably includes $200 for labor (charging a full hour for a job that takes 15 minutes). The intake grate, part 16, is $190 at yamaha sports plaza. I’m surprised they cost that much actually.
Like someone else stated, I would be wondering how it got broken in the first place but if I was the seller
