Humminbird Solix G2
Tranquility Base
I have a Humminbird Solix 10” G2 mfd and my software is up to date. I’ve been having some trouble with the unit in that sometimes on the chart it will zoom out to a .5 mile range, I’d zoom it back in with the rotary knob and it was notchy then as soon as I’d stop it would zoom back out. Over 15-20 mins it would slowly, step by step zoom back in and then be okay for the rest of the day. On my recent trip to Lake Mohave, the touch screen became non responsive, I’d tap several times and nothing, after say 10-20 seconds while I was sitting there watching the screen all those tap commands would execute. That type of behavior reminds me of a PC computer that’s out of RAM ( if I’ve got that correct) memory and or the processor is loaded up and trying to catch up. I had talked with Humminbird tech support sometime ago and that person suggested I export all of my waypoints (I have a lot of waypoints), routes, tracks and settings to a micro SD card, then delete all waypoints, tracks etc off the unit and execute a factory reset. The tech said that it was possible that some of the way points could have become corrupted.
When I got home I did just that with the boat on the trailer, turned the sonar pinging off to keep the transducer from getting hot, the unit now seems a lot smoother in the zoom in and out on the chart and a bit quicker when changing screens. I did have to recreate some of my views, and the unit seemed faster as I created and saved the new views.
All that to say, as with most computers, even with the Linux based Humminbird, an occasional factory reset may be necessary to keep things running their best, and in the case of the OP, the factory reset would eliminate any unwanted tracks. That process may sound difficult but it’s not, the user interface on the Humminbird is pretty straightforward. Note, on my Solix it will only work with a micro SD card up to 32GB, no larger.
My plan going forward will be to first use the unit for several outings with none of my inputted waypoints, tracks etc and see if that solves all of my issues, if it does step two will be to import my I Tracks / trolling routes from the micro SD card that I set up for trolling that I use my Ripe Tide Ulterra to follow over know good fishing spots and see if the Solix continues to perform without issue for several outings. If that works out okay I’ll import all of my way points and see what happens, if things start acting wonky again I’ll know it’s some corrupted waypoints and I can repeat the process up to importing the saved tracks and permanently delete my saved waypoints, unless the I Tracks is and or the issue then they’ll get deleted as well. If none of that works then it will be time for a new Apex.
Edit; If I remember correctly, I think the Humminbird tech said it was possible to load the corrupted way points onto a PC then run a program that would go through the waypoints to find the corrupted waypoints. I’m also wondering if having the corrupted data on the unit is contributing to the heat the unit generates, not unlike a smart phone that has apps that are at war with each other.
@Can0n11
Sometimes that sort of behavior can be attributed to the hardware heating up too - any chance to keep the unit cooler, either by placement or by adding some radiation fins?
Thanks for the good suggestion! The Humminbirds do get warm.. but up until last year it had not affected performance, that doesn’t mean that the heat can now affect it. I usually wet a micro fiber towel in the water and wring it out, then lay it fluffy side up over the back of the unit. I’ve also thought about just trying a piece of CAD, card board assisted design, for shade and perhaps a small 12v fan to try and keep it cool-errr. There are also four threaded inserts on the back that I thought I could use to attach a shade that would allow plenty of air flow around the back.
I appreciate the suggestion and will be sure and take along something to keep the unit shaded..
Best of luck and let us know how it turns out if you go with the mod!
Adding a 12v fan will probably be the easiest solution. They're cheap and keep everything temp controlled. Also, you must have had a ton of waypoints saved but I've seen it happen often that the points and tracks take up so much memory that it slows the units down and makes unusual things happen.
Exactly!
I have found that most times a computer exhibits unstable behavior it is a memory problem… I mean sure if they get real hot too… I’ll try a simple CAD device (card board assisted design) sun shield and see if that helps then will add a fan too…
Thank you for the replay.
I finally got a chance to go out and test my Solix G2 day before yesterday and it worked very well, no issues at all.
When using the rotary knob on the Solix to control the heading of the Rip Tide Ulterra it was very smooth and predictable with no weird jumps further in the direction I was turning it, and even better there were no weird jumps the opposite direction.
When I used the hand held I Pilot remote to change heading’s the adjustments were courser, meaning it would go further in the direction I was changing to than I wanted, but, there were none of the weird reverse changes.
The unit never got warm / hot since it was a cool day out.
I’ll keep using it without importing any of the old nav data and see how it goes.
