Steve89
Hi there new to this forum. I have a 2008 Yamaha ar230. I’ve pulled my port jet pump apart to change the impeller after sucking up a rock. I have the new impeller on the shaft and I’m trying to get the shaft back into engine. It will slide all the way in to where it’s seated but something is pushing it back out about 4 inches. It’s like it’s spring loaded. I did see a few loose pieces of silicon sitting in there before I put the shaft in and I fished them out first. I don’t know how the seal works in there is it possible it’s screwed up somehow? I can bolt it together as is but I’m worried that seal is messed up. Has anyone had this happen? I called the local dealers and they were zero help. Thanks for any info!
