Seadeals
- Greenville, South Carolina
- SX
After many additional hours of operating with the lateral thrusters, I wanted to give an update (sorry if it is less entertaining than the first).
Specific to my “first gen boat” 2006 hull and original pumps with Thrust Vector XLs and Lateral Thrusters, I have determined the lateral thrusters definitely have reduced the reverse thrust in the reverse (idle rpm) detent. If using to slow forward movement, the slowing affect is clearly less responsive now that I have been able to test in multiple conditions with deliberate precision maneuvers. The reduction in the reverse thrust has also affected my neutral (idle rpm) thrust such that the original slight creep forward after several seconds, now results in forward movement right from engine start.
This is not a negative review in any way. I love the Lateral Thrusters and the stern maneuverability they provide, so the reverse difference is a worthwhile trade-off. It does lead me to a point where I think I will make adjustments to the reverse gates for a lower position (more nozzle blockage) in neutral. As for reverse power, I still have plenty available on the water by adding throttle (rpm); but I do have a harder time reversing off the trailer and will just launch a little deeper now.
