Alright, so I am in the same boat as some of you all. 2021 AR250 (small connext screen). Skar 4 channel 500watt amp. 6 new Skar 6.5" speakers. All ohm out at the 2Ohm or 4Ohms as wired from the factory. When connecting the amp, I am using all factory wires, I didnt run any new cables.
- I have verified that my RCA to speaker wire adapters all ohm out appropriately, so I show OL between the positive and negative side of all of my Cress adapters.
- Also verified that my amp accepts anywhere from .2 to 6V input.
- Based on all of that, if I hook everything up and turn on the key, I get the loud static, no sound whatsoever.
- If I measure the mV at this time (no sound, key on) I get 0mV.
- Here's where it gets interesting. If I disconnect 3 of the input RCA's, turn on the key, I get music. Clear as can be.
- At that point I can hook up the remaining RCA's (qty 3), and the music will play throughout all speakers very clearly.
- When I measure mV on the input RCA's I get anywhere between 2 and 20, or more with volume up. I can get this measurement from either the single RCA that is plugged in or the other three that are disconnected.
So long story short, it only acts up when all the RCA's are plugged in. Have you all tried checking this? Do you have the same issue?
I thought perhaps the amp was seeing too much of a voltage drop with all the RCA's plugged in, so I ran a supplemental wire directly to the battery, along with the existing factory red power wire. I was hoping this would help, but sadly it didnt matter.
I'm at a loss!
Any other suggestions?
