FSH 210 Sport
- Tranquility Base
- FSH Sport
Thought some of you may find this test interesting.
K&N filters today are not the same as they were years ago.. and today’s K&N filters, well…. Well read the test for yourself.
What I like about this test is that it was done in a lab, using ISO 5011 test procedures under tightly controlled parameters to test each air filter the same as the next.
I had a K&N filter on my last diesel truck, and was using used oil analysis at the same time. I found this test after getting some high sodium readings in my oil but did not have coolant in the oil which is typically where the sodium would come from. After reading that test I thoroughly investigated the down stream ducting from the K&N and found fine grit that was passing through the K&N filter. The only company that I know of that tests each of their oiled filters is S&B filters.. as you will see in the test article K&N does not test their filters and got pretty hot under the collar when their filters were actually tested against their claims.
