Sam Singh
- Limited S
Hey guys just need help I was 5-10 second late to turn off the water after stoping the engine while fogging the engine . Is this going to cause any problem . After this I did the antifreeze with correct process engine then antifreeze - than stop the antifreeze and after couple of high rpm . Before I stop the engine I ran the air hose with 50 psi while engine was running without antifreeze . Also removed the spark plugs fog the chamber . Gave couple of self without putting spark plugs . Any suggestion for that 5-10 second water I ran after stoping the engine . It is Yamaha 2013 242 limited s 1.8 twin engine .
