Beachbummer
 - Houston TX
 - SX
Hello Folks, This will be a slow hunt, as it's too hot and I don't have much time with all the boating I'm trying to get in before summer's over...BUT
Something is taking 0.03 Amps of power when the master switch is enabled to a battery,, and everything else is switched to off. Everything is powered off that I can tell. I have Lenco electric tabs that have an always on power feed to allow return to the top position when power is "shut off" to the signal wire. I disconnected that and the parasitic drain did not dissapear. I disconnected the voltage regulators, that also was not it. I checked the light in the enclosure, not it. no ground to added ACR, still not it. Disconnected other random things, still not it. I will attack again when there's more time, but I welcome your ideas on what parasitic loads might be present reducing my battery quite a bit if I leave the main switch powered.
The only reason I like doing that is that my Bilge pump is wired through it, and although rare, I do leave the boat overnight in the water before the Marina will move it to Dry Stack. I don't want to leave it without the bilge and float powered.
Worst case I will wire one of the pumps to the battery and extra float, but still I am curious and would like to find this unexpected small drain. Next is to disconnect load from some relays in case any are leaking/sticking somehow.
I have a clamp on AmpMeter, but it is not sensitive enough. I hoped to "Magic Wand" around to trace the power, but no go with this clamp.
Please share your ideas!
Thanks!
Thanks!
