Dagenham Dave
- SX
I just bought a 2019 SX210 and the engines should max out at 7800 rpm. I have read previous threads on this issue, but still have the problem. At max throttles, the port engine goes to 7800 rpm, but the starboard engine only goes to 7400, and boat speed is 39 mph.
1. The display panel records the boat's highest ever speed at over 46 mph.
2. Don't see any impeller problems with the naked eye from under and back of the boat.
3. Adjusted both throttle cables so the transducers go all the way to the wide open stops.
4. Replaced the spark plugs.
5. The color of the old plugs on both engines was light brown indicating good fuel mixture, with the middle cylinders on both engines maybe looking a little leaner.
6. I am running the boat on a river at sea level.
Any other ideas would be much appreciated.
