Jetti
- Zionsville, Indiana
- SX
I have reached the 10 hrs oil change point, and have questions!!
I have an extraction pump and an empty milk jug marked with 1/2 quart lines. I have read run the engine 5-10 minutes to warm the oil, then extract the oil from the dip stick/ fill hole. Then reading online I found a blog talking about removing a hose by the oil filter and extracting the oil from this hose. With this method they say you can extract pretty much all the oil, and not just the 2 1/2 quarts as the other way. Has anyone changed the oil this way before? Some hints on the best way to change the oil on the TR1 would be helpful since it has no dipstick tube.
