tradenpaint
- FSH Sport
Anyone have good or Bad to say about the NAPA's?
They are good filters. Use them at work on everything.
I'd just run the Gold.Wonder if I should get the Platinum or if the Gold is fine just a couple bucks difference?
That part # replaces 5GH1344060 which is crossed over to a Fram PH6017A, WIX 51358 or NAPA Gold 1358.
Cool thanks. If you have a part number that would be great, since I would assume you are using it on your boat. Then I can see if they are locally available.It really comes down to what the absolute filtering is, how many microns and at what % of efficiency. @Babin Farms, do you know these numbers on these filters ? I’ve always seen good reviews on WIX and NAPA filters. Fram not so much, there several u tubes on people disassembling various oil filters, the WIX and NAPA filters do well, the Fram filters that I have seen taken apart are poorly made and many had rust in them.
Im pretty sure the Amsoil filters are 20 microns at 98 or 99% efficiency. I’ll post back later with confirmation or correction.
Wix makes the napa filtersI was thinking of picking up the NAPA Gold 1358 or NAPA Platinum 1358 today at the store. They have them in stock at NAPA. Amazon sent me the wrong ones when I ordered last fall and I gave them to another member they were for the 1.8's.
Anyhow. Anyone have good or Bad to say about the NAPA's?
