drewkaree
- Central WI
The tube is decent. Today is the first day we used it, I picked it up a couple/few months ago as an impulse buy. I wanted something a bit more compact so I can always keep it in the boat. I was running 75' with bungee on the tow rope. It has two valves which are both Boston for the back rest and bottom. the two arm rests are standard valves and there is only two of them as well. Didn't really have an issue filling it, and it is one my easier tubes to fill. It is a definitely smaller than the Super Mable. Although I believe the Super is to be of a much better quality and more rugid. I use my Inflatable dock inflater and set the PSI for each and it went up quick.
I got a chance to tow one of those tubes a few weeks ago and thoroughly enjoyed it. Felt like I didn’t have to work very hard to get it outside the wake.Finally made it out. Alot of Yamaha's on the water today. 250, 252, 222, 195, 210. Saw probably 12 or so flying around. Some not using any common sense in the area where a lot of us where wakeboarding. Still a nice day. The haze is from the smoke from the Canadian wild fires. And the new Costco Tube. Easier to manage than the super big mable.
\View attachment 204178View attachment 204180
I have 2 yo Costco floats that are leaking. Will they just take em back?Just had to take back our 3-year-old tube to Costco. Naturally at this time of year, they don't have any in store, but online shows that one available.
The older model was a PITA for the dividers and head/back rest, 5 valves in all to fill. Am I seeing correctly, there's only 2 main valves to fill? Are they Boston valves as well? I need to replace it within a month, and Costco shows another similar one for a bit more, but I'm glad I have your brain to pick on that one, and your experience with it.
Yes. If you go to the store it helps to have the receipt, but it shouldn’t be required, they can look up the purchase on your membership. If you bought online you can do the return in store. My local Costco can be a PIA on returns and makes up reasons you can’t return something. I just call Costco and they take care of it.I have 2 yo Costco floats that are leaking. Will they just take em back?
