RobbieO
- Sacramento River Delta
- 212SE
So this is inside the anchor locker. I decided to use the rubber washer under the nut. As you can see, the threads are flush with the nut. I cut about 1/4" off mine. If you can get any threads through the hole, just buy a thinner nut and put some 4200/5200 on it. Make sure it's the same BRAND as this:Can you post a picture?
