mark_m
- Columbus, OH
- SX
The babz float in my slip and I use spring lines to actually keep the boat OFF of the babz when she's tied up. As waves come and push the boat into the babz it gently bumps back outward and the spring lines do their job to pull the boat back off the bumpers. It's hard to explain, but I feel very confident that if you use them with front and rear spring lines you will be fine. Hopefully this pic does a better job at illustrating my setup. Let me know if you have questions.Hello Mark and @Crob83, I’m curious what you think about my situation. I just got a 12 foot wide slip. I need good fenders because my slip is at the beginning of the dock system such that I essentially have to dock and then pull into my slip (nice in a lot of ways, actually). I’m convinced Babz will be great BUT my boat (212s) has an almost 8 1/2 foot beam. This means I’ll only have 21 inches on each side of the boat, and potentially slightly less. I noted the Babz say max inflation is 24 inches and normal 22 inches. Obviously (at least I think) the fenders won’t be placed at the absolute widest point of the boat because they’ll hang down, but I’m wondering if it will be too tight of a fit. I’m also thinking it COULD be perfect. The slip has a lift as well. Any thoughts/insights? Thank you!
Thanks
Mark
