KXCam22
- Kamloops BC
I replaced my scupper a couple of summers ago. Interesting to note that a proper scupper is supposed to drain above water. Not sure what yamaha was thinking. I will relate my "lessons" so that others will have an easier time. My scupper was typical. I got scared when I put my trouble light inside the boat and I could see a band of light around the scupper. T0 remove the old scupper I just wiggled it with one hand and it broke off (now more scared). I also ground about 1/8" off 2 sides of the new SS scupper fitting using a file. I found channel locks or any other type of large wrench that I owned impossible to get in there - and turn more than 1/16th. What I finally did was take a scrap of 3/16" aluminum plate and cut a custom (but crappy) wrench and wrapped tape around the handle. That worked great. If you can borrow a large box end wrench to do the job it would be worth while. My big mistake was putting sealant (5200) on the boat. When I slid the scupper in I got sealant on the threads. No big deal I thought, but then found that working in the tight confines with a nut that wont spin freely was bad. Then the sealant started to set up and I was stuck with the scupper nut half way on and had to slowly take it off. The second try worked great, putting the sealant on the scupper unit, threading the nut most of the way on, and then putting the inside sealant on with a finger. Note: I am a more is better guy so I used too much sealant. The other issue I ran into was a leak. After filling the boat up with water it turned out that the leak was from inside the scupper, coming from the hose connection. The stock ribbed hose is not smooth on the inside and so it seals poorly to the barbs on the scupper fitting. It took some sealant and 2 hose clamps to stop the leak. You will note that factory yamaha put a whole bunch of clear RTV on the stock connection. The moral(s) of the story are: don't do it the first way I tried. Get the right wrench. Test fit it to make sure your wrench will do the job. Don't wait to replace this POS. This is not the best pic as my ballast intake hides it but you can see the tight confines for the wrench and the twin hose clamps on the drain pipe. Hope this helps somebody. Cam.
