rghyamaha
- St. Louis, Missouri
- 242 Limited S E-Series
I used Rigid Industries single LED reverse lights. Turns out on my 2020 Shoreland’r that came with my 2020 242SE, there is reverse light wiring in the oem plug, as the disc brakes have a mechanism in the tongue unit that turns the brakes off in reverse. So I tapped that wiring. Ran all wires inside the frame (had to drill one single hole, to run wiring from the port side to the starboard side). Turned out awesome. There’s even holes predrilled in the little triangle “shelves” behind the fenders; used those for the lights.
