keywestdave
Jet boat family, I was out today with my 2008 AR230 HO, and my starboard engine started making a weird noise with a slight vibration coming from that side. Water flowed fine out of the two discharge ports, with no overheating or low oil light on, and then the RPM gauge was acting weird, then the boat stalled. I tried to restart a few times after checking the oil, but it won’t crack over; the engine moves like it wants to start but won’t, almost like something has seized up. I changed the oil, plugs, and filter and regreased the Zirk fittings for the shaft two months ago. The boat has around 400 hrs on both engines, do all my maintenance annually. I’m curious if anybody has had a similar problem like this. I’m hoping the engine didn’t blow up, and I’m stressing a little. Thanks for any insight in advance!
