swatski
- North Caldwell, NJ
I agree about the mat. Yes, our weather is crazy warm, hitting 70s this weekend. I'm pursuing this as fast as I can, which is unfortunately part time, after work and kids. But I have all the parts, more or less, and will start the manufacturing tomorrow - just need to find a drill press.Swatski,
Do you have water to try it in or are your lakes frozen. Was planning something similar with plywood but the horse mat is waaaay better. Cam.
Too funny!!!
Yes I think so. I just got back from the river. I'll try to post some VERY early results. Before I get that call from a divorce lawyer.I like where this is going... that said, anyone think this would be beneficial for a surf wake behind a single pump?
Thanks, when I go into Round 2 of mat cutting I need to be better equipped (with knowledge). The length needs adjustments for sure, so if I can cut it more easily I could test both 16" and 14" and if necessary go back to whatever works best -- I still have a two-thirds of the mat leftover. More importantly though, I'm considering the angle could be critical, I did not appreciate little flex there would be. IDK, any thoughts on that.@swatski - Great write up. I am very thankful someone tried the longer length. Soapy water and a razor blade is a long standing method to cut horse stall mat. You could also try to find or make a knife edge reciprocating blade. Never tried that on this mat but it could work. Again try with soapy water on the mat as this provides lubrication to the side of the blade where the mat is trying to act like brake pads on a bike.
Looking foward to seeing more results. Hope you are not putting yourself in the dog house with the family with all of the time these mods and write ups take.
Good points, @buckbuck. That thing is decidedly in the beastly category right now, it is very heavy. Wielding this thing (alone) under the swim deck is NOT fun. Granted, I plan to shave off a third of its size, but this is never going to be a devise you can store in the cleanout hatch. It does fit in the ski locker in my boat which is, in part, how I determined the longest size I wanted to deal with. And yes, safety straps are a must. I came so-so close to loosing it already in the frigid water.My mind keeps coming back to this mod and how to refine it.
For me, It would have to be easy to stow as I would have to attach it when ready to surf and stow at other times. So I am thinking that the clean out hatch would be the most convenient place. This constraint would limit the size. Any other ideas?
Also, as @swatski alluded to, it would have to be easy to mount. I usually have everyone step to the front of the boat to lift the stern in order to attach the Wake Wedge. I would not want it any more difficult than that.
Due to the weight and possibility of it sinking while attaching this mod, I would want a safety strap to first attach. This way if it got away from me, I would have a way to recover it.
