Scuba_ref
- Buckeye, AZ
Hah! THAT I did not consider, yet.Or some variation of it like this?
I am working of the OP's plan but wanted to test a longer flap since I could not find anyone doing it, and I was just curious what it would do with the water at speed. Frankly I was hoping the jets would force a longer and flexible flap to conform into somewhat of a water funnel. Unfortunately, that does NOT happen.Shouldn't it be about the same size and shape of a right & left wake wedge installed together as a good starting point?
Just a thought...
Yes indeed! "set-it-and-forget-it" is my motto, too.Quick thought on the 30 degree angle. If one were the leave the flap attached out in hot temps for an extended period at any angle that fights gravity the horse stall mat may develop a bend. My selfish interest in this is for knocking down spray at wakeboard and tubing speeds with something that I can leave on all the time. My secondary intrest is improving the wake if possible. That said I will likely stick to straight down mounting angle when I get around to this.
Still glued to this thread to see what does and does not work.
Yes, a loaded and/or ballasted boat is a different beast all together.@swatski For wakeboarding, the list isn't there, but I would imagine that some ballast would still sink the jets in the water a bit.
Yes, that is the idea!Good point on affecting the wake but what if the "acuator" was simply filling ballast? Is there a size and shape that does not have any negative impact on cruising but once the boat is ballasted then has an impact on the wake?
No kidding...I think you need to go pro the polar plunge !
