The official "What did you do to your jet boat today" thread.
First time on lake this year. Had a major fail though, left ladder down on one full lap at WOT. Didn't even notice until I put the boat on the trailer, ladder still down :oops: Thankfully everything looked ok.
I just did this yesterday!! Felt like such a noob. Technically it was only my 5th trip out on a boat ever but still.......
Happens at least once every single trip out. Everyone thinks someone else got the ladder....so no one puts it up, until someone is like wait is the ladder still down?
Had a ladder on the front of our pontoon similar to the Yamaha ladder that would be left down on occasion, couldn't figure out how come we cant get up to speed, asked the wife if she got the ladder. Nope, instant palm to face
Added in the cubby/undershelf and re-positioned my cell phone mount. Waiting on my new 5-gallon dometic that replaces my 2.5 gallon. Replaced bilge pump as the stock finally quit. Hangtyte finally installed on the cover.
Just add water...
Doesnt fit exactly like I thought it would, but it will keep the aft pole light from blinding me at night.
I found a rubber 2 inch pipe cap that I siliconed to my tow hitch and mounted the magnetic based with a bolt and some silicone as I have the same light. I attached a picture for reference. Put a zip around too just for extra measure. Doesn't interfere with a rope and is nice solid surface for light to attach to.
Thanks to @JetBoatPilot added the Seadek pad to the slipperiest spot on the boat, that little landing above the cleat.
I 3D printed a bracket and installed 2x Lumitec CareraLT with a dimmer 'Seadog 403060'. I blew 2 switches before realizing that the maximum rating is 1.5 amps and the light outputs 1.3 amps each. Yesterday I removed 1 light and moved it to the center so it should be good now. The last picture is the lighting output with 1 light and it's plenty.
Probably will be selling the other light and 3D printed bracket within a few days. It's no drill and has foam padding to not scratch the tower point. Installs in seconds. Bringing the wires takes longer, but I found the trick is fiberglass snake with string tied to it.
Hung the box anchor in the anchor locker. View attachment 119747
I've noticed that little fabric latch and knew that's how it was supposed to go......yet mine doesn't seem remotely long enough to wrap around like that. I'll have to give it another look if I bring the boat home this weekend.
If I remember right I had to mess around with that piece and coax it to make it long enough.
Strap in mine does not go over all steps. It goes in between them. Probably if I remember correctly only straps the first step. Then you use the black bungee strap to keep all steps together.
Added some simple storage under seat (saw it on here!) easy great idea to organize things.
Also, made a make shift board slots on the Bimini with some bungees
those mesh bags are slick! Where did you pick those up from?
Just add water...
I like the phone holder. What model is that and how does it mount?
