The official "What did you do to your tow vehicle today" thread.
Been wanting to upgrade the audio in my 2017 F-150. The front doors are 6x9 but I wanted to make the switch to a component setup. Ordered some adapter brackets online to make the install easier (or so I thought)
First thing I noticed is that the tweeter mounts did not fit in the adapters
So I used the Dremel and opened them up a bit
A quick bead of hot glue to seal and secure the mounts
With that out of the way, it was time to bust the pry tools out and remove the door panel
The guts
Test fit is no good. Looks like Ford uses some nonstandard speaker size/bracket
So... time to turn the speakers into brackets...
Cut speaker out
Dremel out the basket and coil
Final product cleaned up
My component adapters then needed be shaved down to fit inside the 6x9 speaker bracket
Mounted the speaker. Glued/screwed all brackets and did a little cable management
Test fit is good!
Removed the speaker and added some sound deadening
Put the speaker back in, put it all back together! Windows go up/down without issue, doors lock, and the tunes sound good :)
... sounds like you'll be rockin' down the road now❗
I like your attention to detail on your installation, ... very nice
We also have the Weight-Safe hitch, ... but I truly like your black better
It was more expensive too. Is yours aluminum? Mine is really heavy
Today I installed the front hitch and put together the cargo carrier. My Firman generator or my Weber Traveler fit perfectly. 500 LB capacity, 9000 LB pulling capacity.
nice...i've been looking to do this too.
any more pics? simple install? anything have to be trimmed?
I had to trim the lower bumper fascia. No big deal. The hitch bolts right in. No mods needed.
Zip tied my front plastic air dam back into place. Thought it was a clunky bearing i just changed out. Was glad to see i just had a curb. A lot would take the thing off but traveling back and forth to Florida means mpg counts.
Replaced the 35's with 37's. Which then leads to the 2" drop hitch not low enough for the trailer tongue. Had to go with a 3" HAHHAHA
2 things.
Joined the front hitch club so we can take boat AND bikes with us
Rigged up camera so I can see what’s behind the boat. I only tow a few times a year but usually a good distance. I’m fine with temporary setup. I need camera to work with cover on the boat. A 1.5” piece of aluminum stock fits snugly in the underwater seat bracket. I just ran a hard wire to house battery, since I didn’t want to leave everything on nd its PITA to get up under cover to flip a switch. The Velcro for the screen works great and I just throw panel back in place when I’m done. I remove camera before launching
Cheers
IMG_3679.jpegIMG_3680.jpegIMG_3681.jpegIMG_3682.jpegIMG_3683.jpegIMG_3685.jpegIMG_3686.jpeg
Good idea! Just don't forget to remove the camera before you back it into the water! (Or is it waterproof?)
It is waterproof but yeah the plan is to take it off first. The camera has a short wire/plug so I can unplug and remove while the cover is still on the boat
2 things.
Cheers
View attachment 244209View attachment 244210View attachment 244211View attachment 244212View attachment 244213View attachment 244214View attachment 244215
Could you please provide a link or links to the camera set up you bought?
Sure. I’ve seen a couple posts around here where folks were happy with this brand even though it is anonymous to me.
