Johanv09
Hello! I have a 2023 AR220 Boat that I love; however, I have been experiencing starting issues with the Starboard Engine Only. After spending a day on a sandbar (4-5 hours), the starboard engine does crank but not start. I have to try at least 10 times after it fires up but after the 2nd try there is a lot of gasoline smell. This issue has become a headache because after spending a lot of time under the sun, everyone is so tired and just want to go back to the ramp and then the starboard engine does not cooperate Has anyone experienced the same issue? If so, have you found the cause and how to fix it?
I have tried to recreate the issue at home running the engine on water hose, but I cannot recreate it. It has only happened at the sandbars. If I stop for 1-2 hours in a restaurant or when I got home to flush it, both engines start immediately.
TIA
TIA
