mntnresq58
- Colorado Springs CO
- SX
Hi all.
So my '06 SX 230 has been great so far.
One issue which I've been working through is the trailer. Mine is the painted version, which has the rear axle disc surge brakes.
For reasons not yet clear to me, the rear axle seems to have a variety of issues.
First, the tires on the rear axle are completely smoked, after about 2000mi. The front axle has a bit of cupping, but not terrible.
Second, the bigger issue is that the hubs on that axle get pretty freaking hot, even after a short haul. Today, after a 4 mi drive, they were so hot you can't grab them. Fronts are cool. I cleaned and repacked both axles last year, soon as I got it home. Bearings and seals are (were then) fine.
The brakes are on the rear axle, so obviously that will input some heat to those hubs, but this seems excessive. It's to the point the rear hub bearing savers are starting to puke grease.
My truck setup probably does bias the weight a bit to the back, but it's pretty close to even (stock Armada, -4 drop hitch).
I'm going to tear it all apart, and repack the bearings, and replace as needed. Brakes don't seems to be dragging. I'll pull them apart and re lube the sliders, etc as well.
Just curious if anyone else has had some similar issues.
Thanks
Thanks
