drewkaree
- West Allis & Fremont, WI
Lol, you beat me to it. I was just going to reply "you could just take the tires off of one side".This one is gonna be hard to steal
I also don't want anything on there that I can't get off myself when I lose the keyI fold the tongue and padlock it. I also insure it for more than its worth.
I like the way you think! lolol.I thought that too but then you take a tire off and put it on the other side.
I could be wrong but I don't think it would drive correctly nor would the suspension flex properly to allow towing if one wheel is removed on a dual axle spring set up. It is different with a flat tire, the flat tire still holds that leaf of closer to it's proper height, when it sags the center axle shouldn't be able to stroke/swing properly. I know when I built my trailer I had a heck of a time installing the spring gear if there was too much or not enough tension on just one spring. Again, I admit I may be wrong on this one.I thought that too but then you take a tire off and put it on the other side.
This is also something to keep in mind. I was on vacation last summer and was using one of those pin locks that goes through the coupler latch, and lost the keys. Needed to get to it in an emergency, luckily I was able to buy a hacksaw somewhere and get in to it. I only have it padlocked when I'm at home, at least I could bust out the angle grinder if I needed to get in.I also don't want anything on there that I can't get off myself when I lose the key
LOL...If someone is stealing the boat, don't think they really.I could be wrong but I don't think it would drive correctly nor would the suspension flex properly to allow towing if one wheel is removed on a dual axle spring set up. It is different with a flat tire, the flat tire still holds that leaf of closer to it's proper height, when it sags the center axle shouldn't be able to stroke/swing properly. I know when I built my trailer I had a heck of a time installing the spring gear if there was too much or not enough tension on just one spring. Again, I admit I may be wrong on this one.
What I'm sayin! I've also had locks rust and seize up.This is also something to keep in mind. I was on vacation last summer and was using one of those pin locks that goes through the coupler latch, and lost the keys. Needed to get to it in an emergency, luckily I was able to buy a hacksaw somewhere and get in to it. I only have it padlocked when I'm at home, at least I could bust out the angle grinder if I needed to get in.
