Amen, the photos above are not due to odd wear or care, those are flat out defects. Nothing would make me switch brands faster than defects that are not covered by warranty.
That being said, any brand can have a defect. At that time, the brand is only as good as who stands behind it when you take it back. As those are defects. The sidewall could have been a road hazard, but it looks like what you called it, a delaminating.
Goodyear endurance from a wholesale club, and never look back.
I don't really do any long distance/high speed towing. My wheels are beginning to rust so I'm going to do the wheel/tire package for convenience. Has anyone used Kenda Karrier tires?
I had GY endurance 2s installed a few years ago on aftermarket rims and note that inOder to reach the max load limit I had to buy not only rims with at Least the same capacity as well as metal stems.
I cannot tell the difference in the ride quality but I don’t worry about my tires anymore.
Recently boating magazine indicated that trailer tires should not be in direct contact with the ground when in long term storage (they recommend that some wood be put between them) but they didn’t explain why. Any ideas?
What did they constitute as "long term" and also what ground are they talking about? Dirt, concrete, asphalt, gravel?
Asphalt, gravel and dirt I can understand due to the possibility of sinking but other than that I'm not sure.
My cattle trailer sits on concrete outside for months at a time without moving and the tires on it were just swapped out at 17yrs old due to the inner carcass letting go on 2 of them. Not sure if they would have lasted any longer sitting on wood over top of the concrete.
Goodyear Unisteel G614 RST I am very satisfied with these tires. These tires have a flat tread that allows the entire tread to rest on the ground, providing good traction
I had Maxxi's on my last Yamaha and Goodyear Endurance on this one. Both are hands above the stock crap that these tires came with. If memory serves me right, the stock tires are C weight rating, and the Endurance is D, as that's what they came in for the stock size. When I bought them the tire shop said it's fine, and the only thing is the boat will ride a little rougher on the trailer. I personally like that I know I have a lot of leeway on these tires. as far as weight.
For me, I keep an eye on the tires and once there's a sign of delaminating or strange wear (they are coming up on 5 years old) I'll replace them. however, since my boat is stored in a covered warehouse in the winter and my garage at the lake in the summer, these tires aren't subject to sunlight and so I hope I'll easily get a couple of more years out of them.
Trailer tire should last about 6 years before it needs replacing. Regardless of its condition, you should change your tire at least once every 5 to 8 years. You can keep your mind at ease while driving in this manner.
I've got 'em. 6 years old. Changing them out proactively. The only ones I've ever had bomb out were the original tires that came with the trailer from Yamaha, but they were 6 years old too.
