Neutron
- New Bern, NC
Those bags will fix your sag but a properly balanced load and tongue weight is the correct way you ensure you are trailering safely. You wont need bags if its fixed. Trust me its night and day once you get it set correctly. Just ask anyone here who fixed their tongue weight.
Why yamaha and most other dealers never set these correctly prior to delivery is beyond me.
My boat was close to 700lbs on the tongue from the factory and it trailered like shit. And the surge brakes engagement was too sensitive.
I moved the boat a few times and got it perfect and then replaced my rear bunks with longer ones to get them to the transom edge.
Regardless of what you do to compensate for sag your not actually fixing the problem. Your putting a lot of unnecessary weight on the ass end of your truck. Not to mention you will wear out your rear tires faster on long tows. And your trailer tires will probably wear unevenly.
