Trailer / Trailering Upgrades
drober30
Michigan
222SD
No - all the holes were already there but I had to enlarge two of the holes about 1/8 of an inch to get the telescoping pins to seat fully. Definitely something to consider on a painted trailer since enlarging the holes will also strip the paint.
OK because I'm sure mine will look like this and there are only two holes so must be different trailers/winch arms.
I'm going to have to take my winch arm off anyway to get to the nuts to remove the factory jack.
Scoop
NJ
242 Limited E-Series
So I upgraded to the Ark and promptly lost the "Magnetic" Handle. My diligent research has in fact confirmed that its not magentic enough to keep from falling off. :eek:
Does anyone know where I can find a replacement.
Thanks Scoop
HangOutdoors
Royal Oak, MI
Reach out ARK, directly, tell them what happend maybe they will send you one, or sell you one. I take my handle off after each use. They are not meant to stay on while towing. Somewhere on the forums, someone used a socket type and a cordless drill and it worked great. Can't seem to find the thread.
I was able to use An 18v Ryobi cordless drill to operate the ark. It worked perfectly if not a little too fast. Bummer on the handle, try etrailer.com, that’s where I bought my ark so assume they have replacement parts as well.
Scoop
NJ
Thanks Guys - it popped up real quick on etrailer.
A little feedback on the rock n hitch ball and cushioned cross bar. After towing with this combo for around 500 miles now, I can honestly say they almost completely eliminate the play which causes clicking noise when accelerating from a stop or suddenly. Worth $150? For me yes.
drewkaree
West Allis & Fremont, WI
Ronnie, are you using a socket on that, or just tightening down the 3-jaw chuck on the drill onto the nub that the magnetic handle attaches to? I've got the Ryobi inflators and pesticide fogger, so one more cheap tool to throw in the boat tool box isn't going to be a deal breaker at those prices, but I wanna know if I'll need to dedicate a socket to the thing.
No socket, the drill’s chuck fits perfectly over the Jack’s handle stub. I will have a Ryobi drill in my on road boat tool box but I’m planning to add two set screws to the base of the handle and keep the drill around in case somehow loose the handle anyway.
Here are a few before and during pics. Summarily, I moved all of the tires and guides between the trailers, and built new bunks for the 2017 trailer. The new bunks are made of pressure treated lumber, coated in flex seal, covered with carpet that is held in place by the flex seal and stainless steel staples. I still need to move the Ramp n Clamp and do some touch up on both trailers and hope to have the 2010 trailer up for sale soon. IMG_3213.jpegIMG_3215.jpegIMG_3214.jpegIMG_3221.jpegIMG_3222.jpegIMG_3226.jpeg
TimW451
Here are a few before and during pics. Summarily, I moved all of the tires and guides between the trailers, and built new bunks for the 2017 trailer. The new bunks are made of pressure treated lumber, coated in flex seal, covered with carpet that is held in place by the flex seal and stainless steel staples. I still need to move the Ramp n Clamp and do some touch up on both trailers and hope to have the 2010 trailer up for sale soon. View attachment 207489View attachment 207490View attachment 207491View attachment 207492View attachment 207493View attachment 207494
Hmm Flex seal, I’m gonna have to think about doing that too. 🤔
anmut
I like the look of that ARK, but having a removable handle is annoying. Do they make one without it? Factory jack is soooo nerve racking...
drewkaree
No, and I had the same reservations as you. Mine is older, so the design may have changed since then, but I've forgotten it several times, and towed with it in place without losing it. Not far, and I try to remember to take it with me when I won't be around, but @Ronnie's post about the drill to lower it was helpful. I just tried it this past weekend, and it does indeed work.
drober30
Michigan
222SD
I lost mine at the boat ramp, had to order a new one for $25.
Ever hear a noise and not realize until later what it was? That was my handle hitting the ground after pulling the boat cover out of my truck...lol
