USB and 12V ports in console not working
Silvershibe
Kansas City
Stupid question on my new to me 2018 210 FSH Sport - The black storage section low on the console has a couple of 12v and a usb port. When I plugged something into it, I'm not getting any charge. I will try looking at wiring inside the console this weekend, but thought maybe someone has an easy answer. If a wire came loose, I would think only one of them wouldn't work, not all. Is there a switch I need to turn on for these to work or something?
bolivas
Prospect Valley, Colorado
Have you tried to reset the breaker right by the USB/Aux and 12V port in the "black storage section low on the console "? It is covered by a black rubber boot and you just need to press it in like a push button. If that does not reset/fix the issue, I would take a volt meter to the connections inside the head behind the curtain on the left side. From there the wires get grouped into a wire loom and have fun with that. If you don't have good voltage at the back side of the plugs before the wire goes into the loom, I would have the dealer check it out.
Silvershibe
Kansas City
Thank you. I will look for the breaker. I didn’t see it. See, I knew it was a stupid question!
bolivas
Only stupid question is the one you don't ask. :winkingthumbsup"
Silvershibe
Kansas City
No luck on the breaker. I guess I'll sweating in the console this weekend.
bolivas
